when i get lifted and you get lowered (you'll probly beat me to it.) we need to have a get together and shoot the trucks together.
itd be liek opposite manches.
the waggy front end or the s10 frame? waggy front end bolts on, not sure on wiring it mite plug right up. s10 frame is a 15 on a scale of 1-10 lol.
  • 3 weeks later...
Yup thats egzacaree what I was thinkin, including the RHD!
Are the waggy front ends hard to find?
what sort of $ at a piuck and pull?
Your RHD as it is, eh?
Waggy fronts are very easy to find over here. As a rough estimate I'd say 10% of older cherokees were waggys. Price can vary between about $10 and $150! U-pull-it is the place to go, as they are very easy to remove.
  • 4 weeks later...
the projects still goin, i got the back half and 4 link done, motor trans and drive shaft in it to :D the waggy front end bolted right up and yes i had to have the header panel as the headlight buckets are different. not sure on wiring tho. i got mine complete from the u pull it for 40 bux :D
as for pics, I'm trying to get it where i can roll it out side and get some good pics, also my sister stole the cord for my camera :mad:
What are you doing for the bed here is my thought when I redue the wife's truck I want to but a step side bed on it like one from an S-10 or something like that any thoughts
  • 1 month later...
I swapped a waggy front end on to my '85 XJ which was a simple bolt on swap of the header panel. the waggy wiring harness plugged right in but it required some very minor modification.
your mj is looking good
[/img]Comanche Club Image Hosting
Cool Grille mod. I'm not the biggest fan of the waggy fronts,(they look kinda old to me)but it is a custom look most people would not recognize.
I'm hacking my old Mj grille for somthing similar(4 lights) but I have some molding and and glass work to do before it's done. What Ru doing for a bumper ? after the new grille a bumper cover is next.
Good luck with this project I'll have to come see it sometime. there arent too many of us lowering mj's especially less than 20 min away.
-Andy
lol yea I'm usin the stock chrome bumper.
hey jb i decided to buy the rhd dash and bezel. i'm not tryin to copy you i've wanted rhd forever plus i'm lifting mine :D but i was wondering, when you put your gauges in that dash, did you just cut off the message center? i "got" a title for my truck so i'm good to go on the whole project, teardown is in 3 weeks once i finish the cherokee i got sittin in the shop and get rid of it :D
