jtdesigns Posted December 29, 2008 Posted December 29, 2008 I was wanting to know wheel torque and thought there was a thread here but did not find it in a search. It would be cool if we started a thread similar to the bolt size thread. I'll start it with the wheel torque found in the 95 XJ FSM :D Wheel Torque = 95 ft/lb
maddzz1 Posted December 29, 2008 Posted December 29, 2008 Hopefully it is a little more successful than the screw/bolt size thread. This summer I am hoping to have my lift on and tear the whole truck down to por15 it. So I should be able to contribute alot to both threads. Some torque specs from the 89 FSM based on bolt size: Bolt size..... Grade 5..... Grade 8 1/4-20..... 95 in lbs..... 125 in lbs 1/4-20..... 95 in lbs..... 150 in lbs 5/16-18..... 200 in lbs..... 270 in lbs 5/16-24..... 20 ft lbs..... 25 ft lbs 3/8-16..... 30 ft lbs..... 40 ft lbs 3/8-24..... 35 ft lbs..... 45 ft lbs 7/16-14..... 50 ft lbs..... 65 ft lbs 7/16-20..... 55 ft lbs..... 70 ft lbs 1/2-13..... 75 ft lbs..... 100 ft lbs 1/2-20..... 85 ft lbs..... 110 ft lbs 9/16-12..... 105 ft lbs..... 135 ft lbs 9/16-18..... 115 ft lbs..... 150 ft lbs 5/8-11..... 150 ft lbs..... 195 ft lbs 5/8-18..... 160 ft lbs..... 210 ft lbs 3/4-16..... 175 ft lbs..... 225 ft lbs
jtdesigns Posted December 30, 2008 Author Posted December 30, 2008 Sweet!! This will be alot faster to find torques then flipping though books, and PDF's.
jtdesigns Posted December 30, 2008 Author Posted December 30, 2008 There are a few more i can get out of the FSM, there's basically a section like that for every section (engine, exhaust, fuel system, etc.). i'll add to my other post when i get a chance to scan them all and resize the pictures. Sounds good! :thumbsup: And to Pete and Eagle.............. You can delete the last three messages if Boiler don't mind.
Boilermaker Posted December 30, 2008 Posted December 30, 2008 I don't mind if the thread is cleaned up of any of my posts. There are at least a dozen pages worth of torque specs. not sure if there is a limit on number of images per post, so they may want to leave the other post too. I cleaned up the first scan (finally got photoshop back on my computer) and posted another one. If anybody has a recommendation on how to organize this better, let me know.
