Guest vzehler Posted June 16, 2008 Posted June 16, 2008 Bear with me folks.... I'm doing a pretty thorough write-up and this is a work in progress while I write it in my free time Well, I hadn't seen a write-up for this prior to doing the swap so I thought I would put a little something together for other's who might be interested in doing this themselves. The Parts You will need to obtain the following parts from a 97+ Jeep Cherokee Sport: 1. Driver's Fender (not in picture) 2. Passenger's Fender (not in picture) 3. Header 4. Driver's Headlight Trim 5. Driver's Headlight/Turn Signal Bezel 6. Driver's Turn Signal 7. Driver's Parking Light 8. Passenger's Headlight Trim 9. Passenger's Headlight/Turn Signal Bezel 10. Passenger's Turn Signal 11. Passenger's Parking Light 12. Driver's and Passenger's Fender Bracket's (See Picture #2) 12. Headlight Harness (You won't need to swap this, but, you will need pieces from it. Not included in picture) The Swap You'll start by removing the stock parts from your Comanche in Preparation for the new front end. Remove the Headlight/Turn Signal and Parking Light Assemblies on the driver's and passenger's side. (See Picture #3)
Casper2000 Posted May 1, 2009 Posted May 1, 2009 UUM hello anyone here? Its dark and scary no one to talk to or finish this write up for us poor folks that could use something to read at three in the morning....... Hello :fool:
BBCchris Posted May 4, 2009 Posted May 4, 2009 Your telling me..... I've been sitting in the garage since June 15 2008 waiting to get this done. I even had it all layed out in the yard just as pictured, then the snow came and after a few months when the snow went away it's getting hard to even see the parts with all the grass that has grown up over them....... Might just have to put it back to stock, that and I have to pee really, really bad. -Chris
Casper2000 Posted May 14, 2009 Posted May 14, 2009 Well at least you didnt buy the cool flip flop's like i did. My feet are just now getting warm again :shake:
JeepcoMJ Posted May 15, 2009 Posted May 15, 2009 someone else will have to take the reigns. looks like vzehler's account is not active (and not existant) anymore.
mfpdm Posted May 15, 2009 Posted May 15, 2009 You can always use the one I did for the 86. Same principles, you just don't have to mod the header like I had to. Here's the link viewtopic.php?f=9&t=11270 :cheers:
relyt120 Posted February 10, 2013 Posted February 10, 2013 no, any 97+ cherokee will have the parts needed for this conversion
dscowell Posted February 11, 2013 Posted February 11, 2013 thats what I thought just wanted to check thanks for the help :thumbsup:
