OK,
I did this a while ago, but didn't see a writeup here, so, here goes:
This was a $500 MJ that was decent, except for a cab corner that had been stuffed (& fixed with ALOT of Bondo!), and a beat up rust rocker on the same side.
I didn't take many pics of the 'damage' directly, but you can see it here:
closeup:
another angle:
I just cut the cab corner off with a jigsaw:
Then identified what was junk under the corner:
and cut that out too,
I used a drill bit to drill out all the spot welds, but they make a spot weld cutter thyat's supposed to work better:
Clean all the gunk out (there was ALOT of gunk in there) & straighten anything you bent in the removal process:
Then just prime & paint (I didn't snap a pic of the final paint):
I bought my rocker from Mopar, but just checked again last week, looks like they're discontinued now. :(
Not a good thing.
Anyway, prep the new rocker for welding.
You're pretty much welding a flat surface to a flat surface, so the prep & burn isn't tough,
getting the hinge support in place was the hardest part (needed to be straightened after removing the old rocker),
and it wasn't that tough after taking a few measurements from the other side to make sure it was lined up right.
Test fit the rocker:
Then test fit the 'new' cab corner (this o0ne was cut off my old trail MJ):
Then burn it in, and prime over any bare metal:
I wasn't in a big hurry to finish, so I screwed the new cab corner temporarily:
and called it done for a while.
I'm lacking a few pics of the corner install,
but basically, I cut it to fit where I had removed the other cab corner,
leaving about 1/2" of overlap,
bought a cheap flanger from Harbor Freight to flange the overlap.
Then burned that in too:
I cleaned up the welds with a flap wheel on the grinder (no bondo for now), got some rattle can Sienna Pearl, and it turned out pretty good for for a trail Jeep:
  • 8 months later...
It's just Chinese Flowmaster copy, by Thrush,
2.5" tubing, offset/offset.
The muffler openings for the 2.5" tubing were way oversized tho, so I had to cut some pie slices out of them, and weld it closed to fit the 2.5" pipe, so I wouldn't recommend it.
It does sound good though.
The doors bolted right on, but the latch post had to be changed to the later style.
I think there's a write up around here somewhere.
  • 5 months later...
