Bobbed V8 Rescue Green 86 MJ
I sold the xj (rusty midwest jeep) and got a 1987 long bed mj for free. The build is getting closer to being "done" so I figured Id throw up a build thread. I have been daily driving this for roughly a year now and just took it apart to finish the motor and do the body work.
Axles
Front HP 44 with warn lockouts 5.13 gears TnT customs truss and stock shafts with 760 u-joints for now
SF 14 bolt with full case Detroit locker 5.13s trussed
Suspension
Looking for a low center of gravity and I am hoping to end up around 5 inches of lift.
T&T customs y-link front
SOA with stock springs and Jks shackles
Drivetrain
383 Stroker all forged bottom end nastyish cam aluminum vortec heads victor jr aluminum intake and holley tbi
Built 700r4
C231
Griffin aluminum radiator with Dirtbound offroad triple 10 fan kit
Interior
Autometer Gauges
everything else stock for now
Body
A good start with ZERO rust
going to bed rescue green
bobbed the bed about 9 inches
Newer style mirrors
Hella housings with IPF fatboys and arb headlight harness
Steering
One ton steering joints with true high steer
Wheels and Tires
Plain jane steel wheels
37in MTRS
Bumpers
Tnt front housing a warn 9500ti with synthetic rope
Aluminum fairlead
Custom built rear with in bed tire carrier
What I started with
Motor and Trans donor
The truck had a bad fuel pump so the bed got removed and another tank strapped into place so it could be test driven.
After test driving the trucks front clip was torn off so the motor could be pulled.
The best surprise of the day.
Got the engine bay all cleaned up and the motor mounts installed. This thing is cleaner that I thought it was. The bottom of the body is in near showroom condition.
How I drove it for roughly the past year or so.
Shot of the dash
Taking the bed off to start the bob
Before the first cut
After cut
Tacked together
Bedsides trimmed
New inner bedsides
Flipped it back over. I used 1/4 inch rod to give me something to not only weld the inners to but it adds alot of strength to the whole side. It also gives a finished look to the bed.
New LED tail lights
Got it in the first coat of primer. Now to sand with 180 then reprime then sand with 320 then seal and color.
Forged H beam Eagle rods and Keith Black Icon forged pistons
I trimmed the rear part of the frame off and got the new cross member remade. Enough typing onto what you really came in here for.
Moved the rear most bed mount
Got busy with a cutoff wheel
New rear crossmember
A little exta bracing
Mount rewelded in
First shot of the bed on
Shot from the rear
Got the bed tailgate and gas door all sprayed today. I also learned my lesson on using cheap paint. I had a brand new gallon of paint that had a bad toner in it and ended up have to buy a new gallon through another paint rep. Hopefully monday I can get my money back on the garbage gallon. It was a 600 dollar lesson today.
There is alot more work to be done. Mostly motor work to make it drivable again. I am looking to doing the 97 up front clip and then I am also hoping to do the interior swap as well.
Wow, looking nice.
did you do the TNT truss yourself? I have a set of Waggy 44s and was looking at the truss. when (if) you got the truss did you order all the mounts already on? or did you have to make your own mounts? I ask because a lot of sites that sell them have the price (base price?) but show the picture of a fully loaded one and it got me confused.
Well I kinda did the one under my jeep myself with supervision from Mike @ TnT. I was lucky enough when I was at school to basically intern there. I have done maybe 5 of them after I move back to Il. I put one under a buddies xj with waggy axles about a month or so ago. If you are looking for bolt in you need the mounts. What suspension are you running or going to run?
I have a rough country 6 inch lift, I will probably swap out the short arms for rough country long arms soon though. when they sell the truss, it is just the bare truss right? and you add all the mounts? cause on their site I got confused as to weather you add mounts to the bare truss or if the options are upgraded mounts. I am pretty sure that its bare then you add mounts but nobody that did a wright up online mentioned exactly what options they ordered.
Thanks the gauges were in exchange for building a jeep for a buddy over the past winter. There is about 800 bucks into them. They are all LED back lit. Here is a picture of his xj.
Not trying to copy the rescue green new interior thing I have been debating the color and swap sense I got this jeep about 2 years or so ago.
  • 3 weeks later...
