Hey, I'm new here a guy member, my name is Sean. I just bought my MJ few days ago, for 1300 Dollars. 4.0l, b/a pukegoat, 6"lift, long arm, 31"at tires, front and rear axles swaps, 4x4. Unlucky, it's pretty need some deep repairs/replaces before go back on weekend road warrior.
pretty in good condition :cheers: But still more repairs/replaces...
most renectly replaced is oilpan gasket and tomorrows job are add new oil and replace lower radiator hose.
then finally is clean up.
  • Replies 69
Cranked up the engine and let it idle to see if there any leak from replace oil pan gasket. There no leaks expect coolant.
The engine bay is cover with mud so I started clean the engine bay little, check the filter and noticed its been all rotted and alittle shrinked. I got it replaced.
  • 3 weeks later...
I am pretty sure I have seen that truck out at the Mounds ORV park about 2 years back. If it wasn't that one it has an identical twin. I didn't have any CC cards with me that day either.
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
reseal my front differential and wow look at those gear oil! :eek:
BEFORE CLEANING
Spray the sh*t it out full of my one brake cleaner can
Took front cover in bath full of water and dishsoap. i ranout of brake cleaner :oops: but i wish i have a solvent bath tank :roll:
scrapped the old rtv seal
AFTER CLEANING
gotta wait 24 hours for rtv to full cure before add gear oil and hope no leaks.
i just realize my 9" rear differential cover is little different which have to remove my both side axle shaft to able remove the differential gear. at least i removed one of shaft out of axle to see kind of bearing to able know which year of explorer and sweetness the axle shaft its self call big bear! I'm happy with my kind of rear. jamminz.gif
thats why I'm look for explorer brake
there NO brakes parts, etc. on my 9" rear
finally work on my transmission
thats how it look before i started
oops....
fix it
pretty heavy duty skid armor
powerwashed the armor
my replacement bellhousing
finally got it out. took me 2 days to work on it to match my errands stuff :fs1:
see the cracked bellhousing? :fs1:
took me 10 mins to purple power it up and wash with pressurize water
installed replacement bellhousing with PROPER tighten!
ready to install back in jeep and installed "new" used slave cylinder that come with bellhouse in shipment. thanks agian to 64 Cheyenne! :cheers:
more pics come up. its done install but need find one bolt for crankshaft sensor :ack: then skid armor then fix the longarm issue
done with transmission's needed... left is reinstall the coil, new shocks, gearoil, front driveshaft and centerconsle
what i did today- refill clutch cylinder and bleed it.
make sure all bellhousing r tighten good
got new bolts for crankshaft sensor.. screw the torx bolts.
grease most the joints
aligment the longarm and regreased it.
removed coils and shocks
reseal the front diff cover
cleaned and reseal drive side rear axle shaft
my 6" lift front coils
damaged shocks(BDS- :ack: )
ready to get longarm back on.
thank god i got np231!
thats pretty much for all day...
installed front driveshaft back on
starting seal my shift boot proper
done
now time to trimming my carpet from tranmission hump
yep alot to trimming
seal and seating on
what did i do with my mj this week:
Added oil in my trans
Running my engine again. Now its shift smooth and easy to disengange.
Reseal my front differential cover with ultra black rtv.
Por15 my front spring coils, long radius arm, heavy duty skid armor and middle cross member
Undercoat spray can paint my coil base and soon drill the bolts for base to retap it. plus upgrade the bolts little longer and grade 8 for coil base seat
Installed wires to my aux fan. Its now run every time I turn parking light on.
Cleaned crap out of my bed thats my brother leave his cj7 part boxes there.
If no leak by tomorrow then there last leaks to fix now are waterpump and thermostat gasket.
  • 3 weeks later...
alot of projects to catch up on this post *beware-alot of pictures*
removed front coil bottom plate-drilled and retap the bolt hole.
repaint the plate and the coils
i used underbody spraycan on plate but por15 on coils
Installed coil back on
remove parts from front dana 44 off to replace axle seals
looks good
solvent bath(purple power)
look at inside of axle guide. pretty muddy
decided to grind the ball joint since lock bolt is seized and the ball joint is excessive loose. I have to replace anyway
Got Front gear Differential out.
feel like to por15 my shaft since its will touch alot of salt, mud, etc since i live near chicago where there tons of salt on road :(
por15 coat after been cover by brake fluid when i removed the caliper out of the way.
guess por15 isnt tough enough anti the brake fluid haha
wirebrushed the long arm
repaint por15 :)
pics of por15 skid armor that i promised to take pics
before skid armor
after skid armor
after put everything back together ill use this new hex head grade 8 bolts for front cover and ultra black rtv is actually stop the mystery leak from cover that I'm been look the leak come from. :fs1: :D go ultra black rtv!
