halnelmar Posted April 11, 2012 Posted April 11, 2012 ok guys, need some help (bet you never heard that one before) on my ignition. i have a new to me 1988 manche, 4.0, 5 speed, tilt column. i have read umpteen posts on this and still not sure where to start. i have a cast on my left hand up to my elbow so i would like to know opinions on most likely things to check because its hard to get under the dash with only one hand. i was doing alot of bouncing around on trails looking at some mountain property and stopped to hike a bit. when i went to leave i turned the key and nothing. turned the key again and nothing. turned key the third time and it stuck in the on position and no crank. had power to everything but now can't turn key off. finally had to take a screwdriver to the starter solenoid and it fired right up and i drove it 3 hours home. got home and key still won't turn off. tried messing with tilt, steering, and hammer tap to key and messing with the lock lever. finally put it in gear and let the clutch out to kill it. opinions? :dunno:
89 shortbed Posted April 11, 2012 Posted April 11, 2012 sounds like the igniton switch came loose and because of that the rod that connects the key to it got stuck. The igniton switch is on top of the coulmn in your conition it would prob be easiest to pull the column to fix.
